Check engine light is on and Volvo dealer tells me the Air Pump # 9179271 needs to be replaced. What does this pump do? I'm pretty competent mechanically, is this something I can repair or rebuild?
Thank you
Bern
98 V70 T5 430,000 km
Bern Davies
- Year and Model: 1998 V70T5
ct98saffv70r
- Year and Model: 98 v70r
it's the Secondary Air System, depends on the CEL code.
Check this out:
http://volvospeed.com/vs_forum/topic/14 ... with-pics/
You can fix this for little more than $15 at Radio Shack and about 45 minutes of your time. i did mine a couple weeks ago and it's been 300 miles and the code hasn't returned. The air pump basically helps trim your fuel levels for emissions reasons.
Check this out:
Bern Davies
Thank you,
If I do this, will the pump be working, or would adding the diode just remove the error message?
ct98saffv70r
You'll just be bypassing its functionality altogether. This will stop the CEL and allow you to actually remove all the components of the SAS and not have to worry about it. It's generally agreed that this system is useless. However be forewarned that this violates any local emissions regulations and should be used as "off road" only, or only as a temporary fix until you can afford to get it working again if you need to pass an emissions inspection.
Bern Davies
OK, thank you
Bern
Bern
obayha
- Year and Model: V70 1999 Base
- Been thanked: 2 times
If it is the pump, a new OEM can cost in the $400.00 range. Water gets into them through a bad check valve usually and fries the motor. I replaced mine the first time with a pump from a VW after doing a little wiring. It worked great, but the holes I drilled in the bottom of the pump to drain off water didn't do the job. So I have gone with the (temporary) fix for now, until I locate another pump. The fix is easy and I think the part cost $1.29 at Radio Shack.
Shane
Shane
1998 V70 T5 331,000
Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
