850, like it's out of gas, turning over with no start
superfing
Year and Model: 96 volvo 850 Wagon
Has thanked: 2 times
Post by superfing »
SO I posted before about a starting problem I have with my 850. Occasionally, my car will not start right away. It basically acts like a car would that ran out of gas, turning over with no start. When this happens I turn my key off and to position II then off a few times and then it will start no problem. My car runs and idles excellent no matter what.
I had the fuel pump then the housing replaced by my shop. I have replaced the relay under the hood, there is spark every time. I am getting fuel to the rail when this happens.
It does seem to be happening in hot weather after I have driven the car somewhere and come back out to leave. Never on the first start of the day. This happened last summer, then went away over the winter and spring after I replaced the pump relay so I thought that fixed it. There are no codes.
Please help??! :oops:
Reason: Edited title for clarity. Removed "!!".
96 Volvo 850 wagon
85 Volvo 240 Wagon DL
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
You can purchase a 'noid light at an auto parts store. Ask someone other than a young kid where to find it...they'll look at you like 'huh?'
Use that to check for a pulse on the injectors when this happens.
'98 S70 T5
2016 Chevy Cruze Premier
superfing
Post by superfing »
I am checking all of them? I have never heard of this. Why do you think this could be a problem?
96 Volvo 850 wagon
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
I've been surfing forums. Somewhere I read a post with symptoms somewhat like you're getting (I think his was starving when hot, but running). A Volvo tech told the owner to check the hose clamp on the hose from the pump to the housing. They come loose b/c they don't have a ridged spur to hold them together. The tech told him to use two clamps on the hose and that would fix it.
It worked. He got full power back.
igel513
Year and Model: 2003 S60 T5
Has thanked: 1 time
Post by igel513 »
"A Volvo tech told the owner to check the hose clamp on the hose from the pump to the housing."
JimBee, pump to what housing?
jblackburn
superfing wrote:I am checking all of them? I have never heard of this. Why do you think this could be a problem?
Just one. Sometimes the fuel injector relay goes bad on 850s.
'98 S70 T5
JimBee
Post by JimBee »
I think the "housing" he was referring to is the pump housing. I'll look at a pump I have to get a better sense of it and post back.
superfing
Post by superfing »
I dont think it is the pump housing b/c it was just replaced and it was doing it before replacement. It was not loose when I looked at it before it was replaced.
I will check the injector and report back after it hapens.
96 Volvo 850 wagon
pkc303
Year and Model: 1995 T-5R Yellow
Has thanked: 1 time
Been thanked: 3 times
Post by pkc303 »
Fuel regulator?
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
Sean-E-Boy
Year and Model: 1995 850 2.3T Wagon
Post by Sean-E-Boy »
Hey,
Just wondering if you ever determined a source for your "like it's out of gas" problem?
I have an 850 that has been doing the same thing off and on for a while now. Never does it when cold never when fully warm, only when i start from cold and drive less than a mile or so (quick run to the store, or to fill up with gas).
I Occasionally get a cel code for front o2 sensor-slow response, replacing both very soon, hope it helps.
Thanks,
Sean
