I have a 2002 S80 2.9 non turbo and have a rough idling issue, at 700rpm. 247,00 miles, bought last year. Have new plugs, 1 new coil, new MAF, new air filter, cleaned throttling valve, used Seafoam, then Gumout to clean fuel injectors via the gas tank, checked hoses for vacuum leaks. I get a "lean fuel mixture" code on banks 1 and 2. What are your thoughts ?
I'm thinking clean the idle air control valve, but don't know where to find it. Is it one of the 3 hoses immediately after the ETM?
rough idle, idle control valve cleaning
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
There is no IAC. The throttle is controlled for idle. Sounds like a possible vac leak to me too given you have mixture codes for both banks...
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
