85 Volvo 240 GL, Sputter, Sputter, Die
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
fesalinas
Year and Model: 240 GL, 1985
Post by fesalinas »
I'm hoping I can get some help with this problem that is driving me crazy. When my 240 is in Park or Neutral, it responds just fine to the gas pedal. When I shift to Drive however the car starts to sputter and eventually will die. It starts right back up and does the same thing. I am not a mechanic, so I know just enough to get me into trouble. Any thoughts, anyone?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
As a good first check with no more info that is provided: go inspect the ribbed hose from throttle to MAF sensor just behind airfilter box. If that hose is cracked when you put it in gear the engine moves to the right and it can open up a split in that hose and the air leak makes the reading from the MAF sensor go low and it effectively shuts off the fuel injection.
A broken motor mount makes the engine motion too much for the hose to withstand, not that the motor mount has to be bad for a 27 year old plastic hose to crack.
fesalinas
Post by fesalinas »
Thanks Jimmy57 but the hose was in tact with no cracks. Any other ideas?
jimmy57
Post by jimmy57 »
cracks in hoses to and from the idle control valve. One goes to inboard side of intake manifold and the other connects to the hose you inspected at the end attached to throttle.
