Sway bar end link issues
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
greekbuckeye
Year and Model: 1999 S80 2.9
Post by greekbuckeye »
Hello all,
I have been a long time follower of this forum and am finally in need of help so I look to you of more knowledge than myself for help.
I have a '99 S80 non-turbo and I took my car to get it aligned and M*das said the front left sway bar end link was broken and the car needed new outer tie rods. After they quoted me $700 for the job and I said no thanks and bought all of the parts online for around $100. I jacked the car up to get to work and apparently the person who owned the car before me stripped the hex keys for the end links and I do not know what to do now. I do not have a torch and wanted to see if y'all could impart any knowledge upon me for this issue. Thank you.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Welcome to the forum!
A monkey/pipe wrench may be able to clamp on and hold the threaded part still while you loosen the nut with a box end wrench.
Coat the bolt liberally in PB Blaster before trying to break it free.
$700 for tie rods?!? Wow.
'98 S70 T5
2016 Chevy Cruze Premier
fn42
Year and Model: 98 V70, 00 S80
Post by fn42 »
This has happened to me a couple times - worst case you can tear the metal link off the ball, grab the ball with some vice grips and twist the nut off
greekbuckeye
Thanks for the help guys. My car has been parked for a while because of a multitude of issues and I finally just drilled out the bolt to hammer in an old torx bit and it gripped well enough to remove.
