850, 1995 Start Problem - no compression cranking
Car is hard to start at times and takes many tries to get it to start. It acts like it is flooded and there is no compression after a second or two of cranking. Sometimes I have to do this 10 or 15 times to get it to start. This typically happens after it is warm and not when cold. I've changed the temperature sensor and checked for leaking fuel past the fuel pressure regulator. I finally held the gas pedal all the way to the floor yesterday when trying to start it and it cranked and started. Not sure about this intermittent problem and where to check next.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Plugs, Cap Rotor Wires? are they real old? Timing belt, been changed recently, maybe jumped time? Oil down in the spark plug tubes?
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
madspeed50
- Year and Model: 1998 S70 T5m
fuel pump tested?
Yep, sent from my rooted, rommed Galaxy Nexus....
jblackburn
- Has thanked: 9 times
- Been thanked: 20 times
Do you have fuel pressure at the fuel rail when the key is flipped on to II for the first time?
It may have a bad check valve on the fuel pump that's starving it of fuel.
I can't think of a reason why the engine would start turning over faster as if there is no compression OTHER THAN the pistons being flooded with fuel, which would probably be the sign of a bad coolant temp sensor. Does the temp gauge on the dash work properly once you replaced the sensor?
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
I believe so. Do you have black smoke at times or high fuel consumption? O2 sensor "rich" codes?
Could be because of leaky injectors.
'98 S70 T5
jblackburn
That code is 99% of the time tied to a vacuum or air leak.
However, I wonder if it could be from leaking injectors or something else causing it to squirt too much fuel into the cylinders.
Do you have a phone that can take videos of a typical hard-cranking situation for us?
'98 S70 T5
- 1777 Views
Last post by Livens
- 14 Replies
- 3481 Views
Last post by dj_v70
- 26 Replies
- 4419 Views
Last post by momentumbob
- 11 Replies
- 4157 Views
Last post by dubsetter
- 1976 Views
Last post by cantgrumble
