How to get ball joint back into control arm?
Jvestal
Year and Model: 05 XC90
Post by Jvestal »
Okay so I am replacing both front drive shaft because of torn CV boots. Got the old ones out and new ones in but can not figure out how to get the ball joint to go back into the control arm. I can push the control arm down (until in bottoms out) but still need another 2 inches to get the ball joint back into the control arm hole. When I jack up the wheel it just pushes out and is not aligned with the hole.
Do I need to compress the springs? Something else? Please let me know any idea.
Here is a youtube link to what I did, unfortunately it does not go into an reassembly details.
Thanks for any info.
Reason: Help removed from title, video embedded in post.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
On 850s I've run into a similar problem, where the ball joint would simply not seat in its mate. So we took the control arm (back) off of the frame of the car. This frees up the control arm so that you can mate the ball joint first, then do the two frame bolts.
Also -> Amazon link
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Make sure the ball joint is clean, put some anti-seize in it then manipulate it where it's at the right angle to go straight in. Depending on how stubborn it is, I've found that using a rubber mallet coaxes it into place.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Usually it is a very long pry bar to get the CA to drop that last little bit it takes for the stud to clear and go into the hole on the CA.
Jvestal
Post by Jvestal »
Here is what I did
road1will
Year and Model: 2004 XC90 2.5T
Post by road1will »
Long pry bar through the control arm prying down. This is much easier to do with the car on a lift instead of the ground.
mbreed
Year and Model: 2005 XC90 2.5t
Post by mbreed »
Volvo has a big C clamp spring compressor that is used on car. I had a come-a-long and just cranked that control arm down until the ball joint went in.
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
Probably a bit late now, but the bolts you loosened are used to hold the camber in position. Might be a good idea to get your alignment checked, or at the very least throw a digital angle finder on there.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
