my car won't somtiems
Airbox Thermostat Cleaning = Better Performance, MPG on Non-turbo's
mo
My car wont start somtimes even though the battery is good. It won't even crank but all other electronics work but if i leave it for a little the cars will than start. do you all have any idea
What is the year and model of your car? Have you checked the battery terminals to make sure they are clean and tight?
2004 XC70
2005 S60 2.5T AWD (gone)
1996 850 GLT Wagon in Blue (gone)
1996 850 GLT Wagon in Green (gone)
mo
the terminals are good and the car has power but wont start
also this problem happend after i tried restting the service light but my car is 1995 volvo s850 glt
new volo 850 guy
i have 95 wagon turbo and have that same problem once awhile. Throw it in Nuetral and try to start it. I checked the dealer and they think its the shifter.
White850Turbo
- Year and Model:
Agreed, sounds like a problem w/ the PNP switch. Another thing to do with the car off and the key in position II is to "ratchet" the shifter through all the gears about 10 times. This helps clean the electrical contacts.new volo 850 guy wrote:i have 95 wagon turbo and have that same problem once awhile. Throw it in Nuetral and try to start it. I checked the dealer and they think its the shifter.
-Sean
1998 S70 T5 (Almost Stock)
