Questions on heater core replacement
carlsun
Year and Model: 1999 V70XC
Post by carlsun »
I have a 99 V70XC, 152K miles.
I'm beginning to notice the smell of antifreeze as well as seeing vapor occasionally coming out of the a/c vents. I have to refill the coolant reservoir about evry other week.
I've looked over several repair explanations and it seems like they gloss over how to remove the lower passenger panel to get to the right side fasteners holding the heater core housing in place. Tips, anyone?
Also, is changing the clips and o-rings necessary on the heater core coupler that goes through the firewall, or only if the leak emanates from there?
Thanks!
Carl S
jonesboy1983
Year and Model: V70 2007
Post by jonesboy1983 »
This may be helpful:
pkc303
Year and Model: 1995 T-5R Yellow
Has thanked: 1 time
Been thanked: 3 times
Post by pkc303 »
Check the write ups here, there are several. It isn't as fun as it looks. We did use the Volvo heater core, as I feared the aftermarket may not line up or fit correctly, and I didn't want to do that job twice.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Removing the lower dash panel on the right side isn't as simple on the 70 series cars as it is with the 850s. You need to remove the torx screws that hold in the glove box, remove the glove box, and then get access to the torx screws that are just below the glove box lip. At that point the lower dash panel should drop down for removal.
If you are just replacing the heater core you don't necessarily need the O rings and spacers for the quick connect on the firewall. When I replace a core though I remove the hoses from the firewall sockets so that I can use a shop vac to suck out the coolant from the core. It makes the job less messy but I still use the plastic trash sacks. Anytime I remove anything on the heating system I replace the O rings and spacers that were removed.
There are two variations of the quick connect connect clips and they need to be replaced as a set so as to assure that they will work - they do not play well together. It is also important that all of the old O rings and spacers are removed from the socket.
Pauloil
Post by Pauloil »
i just did this same job one my 99. after you get the panel out, all you need to do is take out T15 screw on the side of the heater box, then T20 up higher on both sides. T20 holds the pipes to the core. I did not think is was smart to try to clamp the heater hoses, so just pulled out the old core and used old towel to catch the small amnt coolant that came out. ipdusa.com has nice silicone red o-rings. i took the occasion to change my coolant hoses, gates from Oreillys, 22251 and 22253.
99 V70XC 158K
95 850glt 188K
MMT51
Year and Model: 2000 S70 Turbo
Has thanked: 1 time
Post by MMT51 »
Your new core will probably be coated with oil. Make sure to degrease it before installing.I forgot this step and was able to enjoy the oil smell all winter, driving around with the heat up full, windows open, trying to burn it off. I came to miss the leaking coolant smell. I think I saw a recommendation for washing in hot soapy water, or a degreaser like Simple Green or one of the citrus products.
Here's a good tutorial; there are a number of threads on this site.
https://www.matthewsvolvosite.com/forums ... hp?t=40547
Pauloil
Post by Pauloil »
dealer quote: 1,060 dollars for this job. no shit!
99 V70XC 158K
95 850glt 188K
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
Pauloil wrote:dealer quote: 1,060 dollars for this job. no shit!
:lol: :lol: :roll:
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
DrewsT5
Year and Model: '95 850 T5 Wagon
Post by DrewsT5 »
Holy crap! $1,060? Living up to the term "Stealership." That's ridiculous. I just bought mine from IPD a couple weeks ago for around $100, added the silicone o-rings too. I found a local guy on Craigslist advertising this specific job for a couple hundred bucks. I was able to talk him down to $120 for 2 hrs. of labor, since I've got the parts. I've just gotta get to that broken glove box this weekend so I can make an appointment to do this with him.
Sheesh... a grand.
