Hi,
I have a non- turbo s40 (05) and i just installled a new fuel rail pressure sensor meant for a turbo engine. Car runs fine, but i dont know if i should remove it and get the proper non turbo sensor. Whats the difference? Any thoughts!!?? Thanks.
Diff between turbo and non turbo fuel rail pressure sensor
jimmy57
- Been thanked: 320 times
The two engines have different fuel system manufacturers. Denso for non-turbo and Bosch for the turbo'd ones.
The ranges for fuel pressure are the same but that sensor is also a fuel temp sensor and there might be difference there. I can't find signal specification for fuel temp.
