What have you done to your Volvo this week?
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
I thought, instead of ranting on other people's post about the good and bad that go along with owning an older car, I would put it out there in it's own thread for everyone.
I finally finished installing my heater core this weekend and no leaks no runs and no errors. YEA!!
No pictures because the heater core didn't look pretty, but all-in-all the job had a happy ending. :wink: .
For ease of install, I did take out the drivers seat, forgot my wife was the last one to drive it, and didn't hook up the power seat buttons when I put it back in. Needless to say, I was a little cramped driving to work this morning. Raining outside, so couldn't get out and hook anything up.
More things to come in the following weeks, seats, trim, door panels and door locks.
Shane
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
I'm trying to get as much done as possible before the snow starts to fly.
'94 850
Replaced brake pads on all 4 corners.
Turned front rotors.
Changed oil and filter.
Flushed power steering fluid.
Compression test on Cylinder #1 30 PSI Dry - 40 PSI Wet.
Borescoped cylinders - #1 cylinder walls look OK
Marvel Mystery Oil in all cylinders for 2 days.
Sounds like it runs much smoother.
'99 XC
Re-timed camshafts and properly set CVVT preload.
Repaired right front door lock switch.
Traced fault on left rear window.
Ordered window motor.
Repaired right rear seat belt.
Made temporary repair to right rear seat latch - the chucklehead I bought the car from used a Sawzall to cut the latch brace and tore the crap out of the C pillar trim.
Ordered door panel retainer clips and some small misc. trim pieces.
Replaced right side spring seat.
obayha
Post by obayha »
Good golly Mr Lee, I'm just happy to get a darn heater core in.Way to go. :D .
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Pulled the engine out of the 98 XC and then removed the crankshaft and polished the rear main seal surface, Packed the rear prop shaft CV's , replaced front trans (torque converter) seal, and then put it all together.
Oh and I also installed brand new rear calipers with pads and flushed whole brake system.
"new" 2004 V70R got frozen tie rod adjuster jam nut cracked off and replaced and then the toe was set to correct specs with steering wheel centered. Also did trans fluid change, angle gear change, inspected plugs and found them new as well as all new coils already installed recently. Knocked the silly grate out of oil filler (I'm not going to leave oil cap off so the fire protection is moot) so I can see and so the oil goes in as fast as it comes out of jug. Replaced whole rear tail light set with 2005-2007 style I got from local CL for CHEAP (one man's garage clutter is another's new tail lights with factory LED side markers).
On the horizon: Install the ordered larger bore down pipe after I cut and weld in the new catalyst I ordered with mid-body O2 sensor. The already made with adequate catalyst are too much $ and this high flow DP with high flow correct catalyst is cheaper than aftermarket stock. After a little welding that is.
cmblackburn
Year and Model: 1998 S70 T5M
Has thanked: 1 time
Been thanked: 7 times
Post by cmblackburn »
ALL radiator and a couple turbo hoses were replaced with NEW Volvo parts after a major breakdown, heater coupler, silicone o-rings, new outer and inner tie rods and steering rack boots, 2 new continental DWS tires on the back, front end alignment, new (used)drivers side headlight lens, 99 c70 side markers installed, car was washed and waxed and leather treated, and put reindeer antlers and a nose on it :D
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
ChaddGostas
Year and Model: 1996 850 glt
Post by ChaddGostas »
replaced the steering wheel cowling, installed a door striker, ran a can of sea foam directly into my intake manifold via a vacuum hose. Installed an aftermarket stereo with a microphone for handsfree phone use. refilled the oil and did a compression test.
obayha
Post by obayha »
Passenger seat out waiting on new (to me) skins. Odd driving with no seat beside you. A lot more storage room.
I can do in two months, what it takes a normal person to do in an hour.
Shane
