Howling Oil Filler Cap (!)
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
IdahoBob
Year and Model: XC70 02, 04 & 08
Has thanked: 1 time
Been thanked: 4 times
Post by IdahoBob »
OK, rocket scientists!
I saw this listed once and forgot what it was. The fix is on this site, if I can just remember what the gummed up part is called...
My '02 S80 2.9 (no turbo, 210K miles) howls intermittently, sounding like the AC compressor or power steering pump is about to get expensive.
But...if I open the oil fill cap (which is not easy, since it's under a lot of suction) the howling stops.
This is something along the lines of a gummed up crankcase vent.
As said up at the top, there's a documented fix on this site, since the 2.4, 2.5 and 2.9 engines all see this failure.
Thanks for reading, and any help!
Idaho Bob
Thewagonbrokesowestartedfarmin, Nebraska
Idaho Bob
67, 71, 85, 98 wagons (sold)
78 coupe (gave to mechanic, thanks!)
02, 04 (X2) & 08 XC70's
before that: 67 Sunbeam, several pre-68 VW's, '41 Buick, '42 Ford Jeep, and some boring stuff
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The crankcase vapor regulator which is built onto the oil/vapor box on side of block has a ruptured diaphragm. You need to get it fixed as will pull dirt int through the crank and cam seals. The kazoo noise you are hearing is that air being drawn in.
IdahoBob
Has thanked: 1 time
Post by IdahoBob »
So...that's part of the "PCV Breather System" (this is what IPD calls their kit)?
IPD's description makes it look like a not-too-tough project.
Please Advise,
IdahoBob
Idaho Bob
jimmy57
Post by jimmy57 »
The 114532 kit pic shows the box with the round item on top. That is the crankcase pressure regulator.
You removed the upper intake and then the lower intake and the box is on front of the block and very accessible. The intake removal is easy on non-turbos.
