I'm experiencing vibration, most noticeably between 65 mph and 80 mph, when accelerating or decelerating. It almost fades away when driving at a constant speed on a level road. I'ts very bothersome when climbing or descending hills, (with the engine under load - up hill, or under engine braking - down hill). I can create the vibration by accelerating and decelerating on a level road. In neutral, the vibration decreases quite a bit.
My guess is that this is related to a drive axle or the torque converter. Can anyone comment on the cause of this issue?
Steve
2005 S80 T6 Vibration
Steve
2015 S80 T5
2005 S80 T6 (sold, too many problems to fix)
2001 XC70 (sold, now a college car)
1997 850 T5 (sold, then totaled by an oak tree)
1986 960 Turbo (sold)
1984 240D (sold)
2015 S80 T5
1984 240D (sold)
precopster
- Year and Model: Lots
- Been thanked: 128 times
Start with a wheel balance, though this is less likely according to the description, you'll be kicking yourself if you spend $500 plus on axles and find out later it could have been avoided.
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 40 times
- Been thanked: 28 times
Old thread but relevant to my car. I had exactly these symptoms and replaced many suspension components and engine mounts. But tonight I believe I located the root cause, a slightly bent passenger-side axle. Replaced it with a new Volvo part and it's as smooth as silk again. I've read before on other threads that axles are often to blame for front vibrations under load, so I can recommend checking out the axles (driveshafts). Not cheap, I paid almost $600 for the original Volvo part, but the virbration was driving me (pun intended) crazy for the past two years and getting rid of it is worth it to me.
