headache! Help. Putting strut BACK in. sway bar link trouble
VA_Brown
Year and Model: s70 1998
Post by VA_Brown »
I hope someone here can help me. I read up on this process so much I could do it in my sleep. When I actually attempted today, not so much. I needed to replace the strut spring seat. Once it was out of the car that was a piece of cake.
Now- getting the whole struck back in my car- proving impossible!
I have a volvo '98 s70 2.4L no turbo.
I cannot get the strut back in the car because the sway bar link bolt is too high up to fit into the hole when the 2 lower bolts are in and secured. Is there a way to do this without
#1 breaking something- namely the sway bar link
#2 having body bulider strength
#3 having a 3rd arm or another person to help.
The videos and picture guides I have seen make it seem like a breeze (kind of) to get the thing back in there.
Really appreciate any help! Good thing I have a 2nd car otherwise I would be SOL....or bribing the mechanic a block away to come fix it.
VA_Brown
Post by VA_Brown »
At 6min 13 sec in this video. Mine was not like that at all.
Could this be due to my car only being jacked up on one side??
Ben850
Been thanked: 7 times
Post by Ben850 »
VA_Brown wrote:at 6min 13 sec in this video. mine was not like that at all
could this be due to my car only being jacked up on one side??
Absolutely.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I did the same job yesterday, just set a floor jack under the control arm and jack the control arm and strut up together until the sway bar end link just fits right into the hole.
wheelsup
Has thanked: 15 times
Been thanked: 20 times
Post by wheelsup »
I used a pry bar to pry the sway bar with end link attached down enough to slip it in up top and tighten it down. Using a jack would probably be a lot easier though.
VA_Brown
Post by VA_Brown »
Thank you for advice!
This job may have been a teensy bit out of my skill range, but now I feel like a pro! nothing like spending a cumulative 8 hours or something at a task!
All that work for one little spring seat. gosh! But I finally got it done today because the strut nut too came in. And I drove it..... and no more clunking! yay.
Thanks all, really appreciate the expertise here.
Jacking up the control arm made putting the sway bar link back up a breeze.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Well now it's well within your skill range and you can do it over again if you like with ease.
