I have a 2001 V70 T4 that stalled yesterday and needs a fuel pump relay.
Spent last night and this morning searching online for location of fuel pump relay. Went to the wrong forum, I'm back again.
Does anyone recognize this fuse box? I took the torx screws out. Doesn't look like there is room in the box for the relays. Should I open it up? Thanks for looking.
Kevin
2001 V70 P2, where is the fuel pump relay located? Thanks.
KevinCollins
- Year and Model: 1998 V70
- volvo fuse box.jpg (275.54 KiB) Viewed 17473 times
- P110412_1355.jpg (283.63 KiB) Viewed 17446 times
fuse box on left side just under the hood. take 4 torx screws out and remove the plastic/rubber cover around fuses. There it lies! sorry, thought you had a P1 model
99 V70XC 158K
95 850glt 188K
95 850glt 188K
KevinCollins
I took out the torx screws, but the fuse board seems locked to the box. There are snaps on the front, can't see any on the back. Should I just keep prying? Does it snap off? Don't want to break it unless necessary...
Or should I take the shroud off under the steering wheel, no snap-open fuse box seen.
Thanks.
Okay, I'll open up the dash.
Took off panel under dash, not there!
Next, remove torx screws and keep prying until something gives. Oh, well.
Thanks.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Since you originally posted your question in the wrong section,
(1993-2000 for Gen 1 P80's ) you probably got the wrong answer.
The newer P2 V70's from 2001 onward are
completely and entirely different vehicles.
The posters here in the 2001-2010 section
should have all the right info for you.
- BEJinFbk
This should get you there:
You can download the entire wiring diagram PDF here:
https://www.matthewsvolvosite.com/volvo-wiring-diagrams/
- 5220 Views
Last post by wizechatmgr
- 11 Replies
- 2811 Views
- 16846 Views
Last post by Richard99
- 1600 Views
Last post by quietlymknnoise
- 6658 Views
Last post by 2007volvos80
