O2 Sensor ~ Where is it located pn a 1996 960
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
davolvo
Year and Model: 1997 850 Sedan Base
Post by davolvo »
Hello, can someone please tell me where the O2 sensor is located on a 1996 960? Thank you!
Proud owner of a 1997 850 Sedan Base
Gatewood
Year and Model: 1996 960, 2002 V70XC
Post by Gatewood »
Look at the top of the catalytic converter and the exhaust pipe underneath your car in the center. O2 sensor codes can be caused by other stuff, though. If this is related to that fuel smell you're getting, check your vacuum hoses around the intake manifold and other hoses in that area.
davolvo
Post by davolvo »
Ok, thank you so much! Exaclty how many hoses are there? I haven't messed with vaccuum hoses before. What should I check for? Should I clean them or blow them out? Thank you in advance for your help.
