How to replace ignition switch
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
travis873o
Year and Model: 1990 740T
Post by travis873o »
So I'm about to tackle replacing the electrical part of the ignition switch assembly in my 90 740 turbo. The ignition is located on the dash.
What are the steps to replacing it? I pulled the dash cover off around it and couldnt figure out how it comes apart.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
1. Disconnect the battery negative lead.
2. Remove the trim panel from below the steering wheel.
3. Disconnect the multi plug from the switch.
4. Remove the two screws that secure the switch to the steering lock. Withdraw the switch.
5. Refit by reversing the removal operations. Note that the hole in the centre of the switch is shaped so that it will only engage with the driving spindle in one position.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
