Did you change the axle seal...
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
...when installing the rebuild axle?
It is original, and appears aged, and discolored, I will post photos later today.
Could it be cleaned, restored like a shoeshine if not damaged?
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
If mine have been in place for more than around 50k miles I just go ahead and change them. They are relatively cheap and they are very easy when the axle(s) are removed.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
I did. One didn't want to come out, but I used pliers with a tooth and bent the seal out. No style points given, but it's out.
Also -> Amazon link
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
Last time I changed one I used a long, thick-shank screwdriver; laid it across the seal, tip under the seal ring on one side and pried it out by pushing the screwdriver against the other side of the seal. It resisted but eventually came out.
Next time, I will use a 2 foot crow bar (gently, of course), to get leverage so I can control the pop out more easily.
Year and Model: 2004 V70 2.5T
Been thanked: 474 times
Post by cn90 »
Use sheet metal screws. I posted the trick in rear cam seal DIY.
I'd get the seal from Volvo dealer.
A good alternative is SKF seal.
This is a job you don't want to do again if you get a leak from some cheap after market seals.
xHeart
Post by xHeart »
cn90 wrote:Use sheet metal screws. I posted the trick in rear cam seal DIY.
Thank you for the tip.
I found this Volvo P/N 6843112. Is this correct?
It appears to take two, one for each side.
I will also call local Carquest for SKF.
Post by cn90 »
Yes, Volvo 6843112 is the Auto Trans seal.
You need qty = 2 (1 on each side).
Volvo OEM is about $22/each.
SKF is 15737, check to be sure, about $12/each.
IMHO, if not sure, stick to Volvo seals.
xHeart
Post by xHeart »
cn90 wrote:Yes, Volvo 6843112 is the Auto Trans seal.
Replacing with Volvo seal would ensure Raxles' rebuild is closer to CPO standard.
Thank you for the diligence cn90.
Post by cn90 »
To remove the old seal, use the sheet metal screws trick as mentioned in this REAR Cam seal DIY:
https://www.matthewsvolvosite.com/forums ... hp?t=50752
To install new seal:
- Make sure the "garter spring" goes inside.
- Use appropriate socket (or plumbing PVC coupler) to drive it in. Wet the seal with small amount of oil first.
PS: I understand your car is on jackstand waiting for Raxles.
Don't leave the trans output holes open too long, you never know bugs, flies etc. crawl inside the trans.
Debris, dirt is the #1 enemy of any trans.
Just use masking tape to tape the opening for now.
xHeart
Post by xHeart »
What is "garter spring"? Sorry.
