I have a 2000 S40 1.9T with an oil leak from the cam seal inside the cam sensor housing. Can I replace the seal by simply taking the cam sensor housing and cam sensor ring off the cam and pulling the seal out or do I need to remove the valve cover to get to it? I am trying to avoid pulling the timing belt since it and the front seals were done by the previous owner not long ago.
Thanks for any help you can give me!
Rear Cam Seal Leaking Out of Cam Sensor Housing
- 22 Replies
- 9632 Views
Last post by ggleavitt
- 1312 Views
Last post by iRenaissanceMan
