964 1991-94 Rear suspension mountings Beware
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
gmtgmt
Year and Model: Volvo 850 T5R
Has thanked: 1 time
Post by gmtgmt »
Thought i might share this.
I have had some problems with my beloved 964, it made a hard clunk sound when i put it into gear or started out from a dead stop. i thought this was the bushings, as they where on my old 764 TIC.
So i was replacing the driver side rear spindle as one bush was bad there, and i hoped it would stop making the clunk sound.
(I had complete rear supsension from a good parts car)
As i was putting the brake rotor on i notied there where some seriours rust where the front mounting bolts for the rear subframe was.
the more i poked at it the worse it was the whole front end of the subframe mounts to the body was rusted away. but i noticed that it was bolt on brackets where the spring sits. look them up at work today and they are avieble still from volvo but only as "GCP" and they where cheap.
So guys in the rust belt be aware of these brackets
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Good advice, thank you.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
gmtgmt
Has thanked: 1 time
Post by gmtgmt »
Here they are replaced took about 5 hours
not bad only rust this has for 22 years and almost 400.000 miles living by the Sea and in the rust belt too all its life
