I have a hard time telling the difference between two similar offerings from FCP and IPD:
http://www.fcpeuro.com/products/volvo-p ... bo-v70t100
http://www.ipdusa.com/products/4988/114 ... xc70-turbo
Any thoughts on why the one from IPD is $140 more expensive?
Thanks.
PCV System from IPD or FCP?
VolvoMonkey
- Year and Model: V70 XC 1999
Gubernaculum
- Year and Model: '00 s70
The one from IPD includes the long line that snakes around the engine from the turbo to the oil trap.
I got the cheaper one from FCP. I meant to remove the non-included line and clean it out, but I got so frustrated with the job, and had a limited time table, that I just hooked it back up and hoped for the best.
I had a terrible time removing the manifold on my car - yours is probably different than my 2000 s70 glt se, but if not, then FYI that weird thing on the fuel line that snakes above your intake mani is a quick-disconnect that you can disconnect with a screwdriver, or a special tool. I think I added pics to the PCV thread.
- Year and Model: Many Volvos
- Been thanked: 75 times
My preference between the two is IPD's kit. They send real hose clamps rather than oetiker clamps and they also include a new set of injector O rings. I have an oetiker crimp tool but there simply isn't room to make it work.
Unfortunately, the IPD kit has some of the same crappy URO hoses that the IPD kit has. The hose from the oil trap to the block is a very important hose and I have seen pictures of the URO branded hoses where they have just swelled up and started to disintegrate. For that hose I buy Blue Box and just throw the URO hose away.
- BlackBart
- Has thanked: 927 times
- Been thanked: 884 times
Last time, I bought the kit that was all Volvo bits for peace of mind. Inside that long hose assembly is a small plastic hose that gets brittle and can snap if you’re manhandling it between obstructions.
- Has thanked: 1842 times
- Been thanked: 1710 times
I had a kit from IPD with that short URO hose that lasted all of about 500km before splitting. Love do-over jobs!
They did change it for a while to a Volvo hose, have they changed back?
I prefer Oetiker clamps to the screw type, but then I have multiple Oetiker clamp tools that can work from the end or the side.
FCP also has the lifetime warranty!
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I'm cracking up at the distinction between Oetiker and "real" hose clamps...
- Has thanked: 1502 times
- Been thanked: 3817 times
You can use big dikes to crimp an oetiker in tight places. Sounds too personal. Make sure any hose that sees oil is blue box , indeed.Ozark Lee wrote: ↑23 Nov 2012, 21:39 My preference between the two is IPD's kit. They send real hose clamps rather than oetiker clamps and they also include a new set of injector O rings. I have an oetiker crimp tool but there simply isn't room to make it work.
