P1132 code
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Ralph3
Year and Model: 2001 V70 T5
P1132 code
Post by Ralph3 »
According to my OBD II reader the P1132 code is a bad O2 sensor. I purchased a o2 sensor, installed it and ran for several months with no check engine. Several months ago I got a check engine, called the supplier of the o2 sensor and he said the sensor was not bad, I have a vacuum leak on the passenger side of the engine giving that code. I replaced the vacuum hose from the center of the intake manifold over to the drivers side of the engine. Drove the car two days and the OBD II reader said theer was not codes. Several days latter a check engine appeared and the P1132 code was present. Do I have a vacuum leak or a bad o2 sensor? I cannnot see any vacuum hoses on the passenger side of the engine unless I remove the intake manifold. Is this the next step or should I get another o2 sensor?
