car wont start
I have a 2005 s40 that wont start. It sat in the freezing weather for a night and wouldn't start the next day or any day after for about 6 days. Initially it wouldn't do anythng when I turned the key but would turn over with a jump but not fire up. I changed the battery and put some dry gas into it but it still wont start days later. It currently still only turns over and does not fire. I though it may be water in the fuel lines that may have frozen but today is about 50 degrees and it has 3 cans of dry gas in w/alcohol. Does anyone have any ideas what it could be or what I could try?
I am having similar problem, however I eventually could get the car started it just will not idle. Did you try giving it gas while starting? An OBDII scan might help tell you if a sensor is malfunctioning. I am thinking mine is the Idle Control Valve stuck or broke but not ruling out fuel injection system.
2001 Volvo S40 1.9T @ 167k
1995 Volvo 850 GLT @ 201k
- 1217 Views
Last post by whtwgn
- 1321 Views
Last post by ordinaryboy1986
- 2021 Views
Last post by ejbj
- 491 Views
Last post by teachme
- 1487 Views
Last post by emtor
