Cranking But Won't Start Topic is solved
Guest
I have a 2000 S70 with 96,000 miles on it. Last did a tune up at 90,000. It had been sitting for about a week, started it briefly shut it off and left it for about 3 days. Now it will crank but will not fire up. Never had a problem like this before. Any advice?
victorn
that battery??? he said it cranks but will not fire!!!!!!!!!!!!!!! there could be lots of things....i'll start with the fuel pump
Guest
This site had the answer. I tried it and it worked, the car started up on the second try. I turned the key and pumpe the gas at it fired up slowly and ran well.
http://forums.swedespeed.com/zerothread?id=46707
