Coolant Leak, any ideas?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
baumr1
Year and Model: S60, 2007
Post by baumr1 »
My 2007 S60 has a slow coolant leak. I have to fill it about every 3 months. While changing the oil, I pulled off the lower valence to see if I could see the source of the leak from underneath. It seems to be leaking from where the plastic joins the metal core on the passenger side. It's difficult to see in the picture but if anyone has any ideas of what this could be i'm open for suggestions. More than likely i'm going to need a mechanic to fix it, but i would like to atleast be informed before I go in and get ripped off.
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
It would be a good idea to check the top hose for leakage. Water may run down along the tank. Tighten the clamp. Check for white residue.
Other than this, the radiator/tank assembly needs to be replaced.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Difficult to tell which side of the radiator this shot is of, however it's likely from the same side as the upper hose connection which often cracks, then runs coolant down the radiator to the lower seam.
This will fix the problem: http://www.eeuroparts.com/Parts/38183/Radiator-65553A/
Expect around 2.5 hours of labour to remove and replace according to recommended shop times by Volvo
crazyace1104
Year and Model: 2005 Volvo S60R
Post by crazyace1104 »
baumr1 wrote:My 2007 S60 has a slow coolant leak. I have to fill it about every 3 months. While changing the oil, I pulled off the lower valence to see if I could see the source of the leak from underneath. It seems to be leaking from where the plastic joins the metal core on the passenger side. It's difficult to see in the picture but if anyone has any ideas of what this could be i'm open for suggestions. More than likely i'm going to need a mechanic to fix it, but i would like to atleast be informed before I go in and get ripped off.
Radiators fairly easy to replace. Do you hv tools and any mechanical background?
