98 s70 fwd suspension ?'s
rgcustom
Year and Model: S70 GLT, 1998
Post by rgcustom »
What is the difference between fwd and awd front suspension? I found a kit that is for a full overhaul bit it is for awd only. I would like to know so I maybe wont have to spend the extra $200 on the extra party's for the fwd kit.(extra parts meaning control arms, end links, and tie rods)
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
Absolutely nothing in the front end, suspension wise. Can't remember if the awd 98 has the four bolt control arms or two bolt.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
AWD uses the five bolt wishbones, four through the subframe and one for pinching it to the strut
FWD uses the three bolt wishbone, two through the subframe and one for pinching it to the strut - Mike
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
FWD wishbone with 3 bolts. Picture showing 1 bolted to subframe.
'97-850, driver's side control arm bolted on to subframe
rgcustom
Post by rgcustom »
Thanks for the clarfication. I have already had the front struts replaced, but I am still getting a cliking and knocking sound from the front left side when turning the wheel sharply in either direction.. Any ideas on what needs replacing?
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
sounds like the front CV axle. Has to be replaced.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
I sure hope you installed new spring seats when you did the struts?
Other noises
Bad sway bar end links
Bad control arms
(and axles)
rgcustom
Post by rgcustom »
Other noises:
Sounds like something is rubbing or draging the break,
moderate vibration (mechanical) with low speed acceleration( i.e. going over speedbumps)
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
CV joints.
'98 S70 T5
2016 Chevy Cruze Premier
