965 1995 Speedo dosent work Rear sensor and ABS is working.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
gmtgmt
Year and Model: Volvo 850 T5R
Has thanked: 1 time
Post by gmtgmt »
I bought a 1995 960E 2.5 M90 trans. Needs some work. One of the things is the speedo doesn't work but the Rear sensor and ABS is working. Have tried with a different instrument cluster and nothing .
Any imput?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
How did you test the sensor?
One of the main causes of failure on this type of speedo is at the sensor connector which becomes oxidized. There may also be a metal wire seal on the connector which has been known to cut through the connector and into the wiring.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
gmtgmt
Has thanked: 1 time
Post by gmtgmt »
billofdurham wrote:How did you test the sensor?
Bill.
if the sensor didnt work ABS light will come one and if i remove the plug in trunk (from the sensor) and put a multimeter between the two from the sensor it generates a voltage like it shold so and it indcresses the higher the speeds are.
also the ABS light comes on and stays on until i plug it back in
