My front tire (drivers side) when lifted off the ground has about 1-1/2 inches of play in it side to side (nothing top to bottom). The passenger side has no play. Any idea what can be causing this issue?
Thanks!
Tire wobble
- regent
- Has thanked: 2 times
- Been thanked: 12 times
It could be a bad tire, a bent wheel rim, hub runout or any combination of these. Can you see wobble in the wheel rim or is it just in the tire itself?
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired
1987 340 DL - retired
2015 BMW 335i
thanks for the reply! the rim itself moves about 1-1/2 inch. the rim is not bent and the tires are brand new (maybe 5,000kms on them). I thought it may be the hub, however the hub would result in my car shaking at all speeds, not just at high speeds (which it does)... Any other suggestions? Thanks!
- Has thanked: 2652 times
- Been thanked: 1245 times
Sounds like inner or outer tie rods. The car follows grooves in the pavement?
- regent
Yes, check to see if the play is in the horizontal plane only (grab the wheel at 9 and 3 o'clock and try to move it) - this will indicate worn tie rod ends. Next, grab it at 6 and 12 o'clock to check for play in the ball joints and control arm bushings (or you could use a pry bar under the wheel)
More hints: http://www.ipdusa.com/techtips/10029/ch ... g-for-play
Credits: IPD
Credits: IPD
2015 BMW 335i
2015 BMW 335i
Just an update: I took the car over to a mechanic. We took the wheel off and had a look. It turns out it is a lower ball joint on my drivers side. I thought it would be the tie rod ends so i'm still a little worried about his findings. The wheel has absolutely no play top to bottom (12-6) but it had play side to side. Could this be caused by a bad ball joint or should I have it looked over by a new mechanic?
Thanks!!
Thanks!!
- regent
Since I am present at the scene I would ask him (or her) kindly to show me where the play is and I would even take a picture or two for my recordsWe took the wheel off and had a look.
2015 BMW 335i
2015 BMW 335i
My apologies, I shouldn't have used 'we'. He took the tire of and those were his findings. I did some research online on how to check the ball joint as well as the tie rods, so I am going to take a look myself and see if I can determine the problem. I will take some pictures and post them tomorrow in regards to my findings. I personally think it may be my tie rods, but they were replaced about 2 years ago. They shouldn't go that soon should they? (replaced by volvo).
Also, the car does not shake at speeds lower than 80kmph (approx 45mph i believe). It also does not pull to one side, just shakes the heck out of me as i drive. Won't a bad tire rod cause the vehicle to pull to one side?
Again, thanks for all your input, i truly appreciate it!
- regent
Good thought.
If you are lifting up the car, please remember Safety First!
2015 BMW 335i
2015 BMW 335i
