Check Engine Light
Guest
Check Engine Light
Post by Guest »
My check engine light came on a few days ago.
I live in Sacramento, CA. Does anyone know of a good mechanic in the area? Do I need to get a diagnostic test? How much do they range in price? What's the common cause of a check engine light coming on? If it's the oxygen sensor, is that easy to replace (i'm a self fixer)?
Any help is appreciated. Thanks.
bigern
Post by bigern »
i would go to auto zone and get them to pull the codes, then post them. if its an oxygen sensor code DO NOT change it immediately. post the code numbers and check the responses....
Guest
Post by Guest »
So I went to AutoZone, diagnostic read:
P0442
EVAP Emission Control System Leak (Small)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2663 times
Been thanked: 1256 times
Post by matthew1 »
Sounds like a vacuum leak. Check your vacuum lines and elbows.
Also -> Amazon link
guest
Post by guest »
I'm sorry, but I'm having a similar problem but am not a do-it-your-selfer. I definitely want to learn if possible. If you happen to have a schematic of the vacuum lines and elbows, that would be great. Thanks!!!
vicney
Post by vicney »
check your gas cap!!!!
matthew1
Site Admin
Post by matthew1 »
Sorry, no schematic. Vacuum lines are white in my 850.
Gas cap is a usual suspect, absolutely.
Also -> Amazon link
original guest
Post by original guest »
I haven't had the time to check my vacuum lines, but I went into Auto Zone to borrow a DBII to reset my service light. I erased 1 the only code it found, and my check engine light went away. I've only started the car a couple of times since, but could the check engine light really be a error in itself? Or a faulty electrical problem?
Thanks for all the responses.
matthew1
Site Admin
Post by matthew1 »
Could it be an electrical glitch? Sure.
I haven't heard of this happening often/at all, so I would guess it's a real fault (or was) in the emissions system.
Also -> Amazon link
Barry Munroe
Post by Barry Munroe »
Hi Guys
My CE light just came on after I got gas, how can the gas cap effect the CE light, or do you think a vacuum leak? THANK YOU IN ADVANCE
