xc90 struts on an 850?
timmyc
Year and Model: 93' 854 GLT
Post by timmyc »
So I need struts on the 854 and there are some xc90 struts literally laying on the ground at the local u pick it. Will these work?
I know everyone says to use the seats and mounts from the xc90, but do the struts work as well? It shows that the same strut can be used on a V70 as an 850, so I wonder, will it work?
93' 854 GLT 212k
97' 854 GLT 115k
97' 328i 252k
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Nope and nope!! Everything past 2000 was re engineered. Pretty much the only shocks that match with each other are P2 S80s, S60s and V70s.
timmyc
Post by timmyc »
But isn't a V70 essentially a Cross Country with awd? And I believe it is a '98.
I just realized that it is a CC not an XC90. So, same question. Will '98V70 CC work? If the struts are the same, would I just reuse my springs to account for the weight difference?
93' 854 GLT 212k
97' 854 GLT 115k
97' 328i 252k
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
They will fit but would be taller and an educated guess would be that they would not work too well with shorter springs!! :!:
(A big sigh here)!
timmyc
Post by timmyc »
(big sigh back) Not what I wanted to hear but appreciate the help fellas.
93' 854 GLT 212k
97' 854 GLT 115k
97' 328i 252k
precopster
If it makes you feel any better you can use XC90 strut mounts on the 850 due to the part number (30683637) from the XC90 now covering all models. This doesn't apply to the aftermarket units which are just copies of early build 850 spring seats.
timmyc
Post by timmyc »
I just ordered all the goodies from FCP. Doing A arms and links and all that good stuff while I am in there fooling around with the suspension. Car only has 115k on it and I am surprised that both the struts and mounts are bad. Our other 850 has like 204k with all the original suspension and it is 4 years older. Go figure!
93' 854 GLT 212k
97' 854 GLT 115k
97' 328i 252k
