Coolant swoosh!
94 850 140k na.Whenever I start the car put it in drive and accelerate I get a sound that I can only descibe as water (coolant) rushing(swoosh) through the fire wall or the heater core.It only lasts for a second or two,but its loud.I guess this sounds strange,but its the best description I can give....thanks in advance
Ben850
- Been thanked: 7 times
I am imagining water under your front cowling in front of the windshield. If you don't have a cabin air filter, it might also find its way into the fan area.
You might check to see if the drains are clogged from the cowling area.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
My 96 used to do the exact same thing.318mike wrote:94 850 140k na.Whenever I start the car put it in drive and accelerate I get a sound that I can only descibe as water (coolant) rushing(swoosh) through the fire wall or the heater core.It only lasts for a second or two,but its loud.I guess this sounds strange,but its the best description I can give....thanks in advance
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Pulled off the cowling,no water anywhere that I could see.Its really strange but it only happens on the first time I accelerate after startup.The rush of water sounds like its being forced under pressure,like a sudden rush of water through a garden hose.
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
Have you recently drained the coolant and refilled? Every time I have changed a radiator in one of these it has done that on he first test drive. the heater core has to fill up and I believe that sound is the water pump pushing water thru the system. Just been my experience.
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
My car did that for years until I changed the heater core.
Heat always worked just fine.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
It started leaking (don't think that was the cause of the sound; just something that happens to all of these cars).
If you've never done a coolant flush, this may be an excellent time. Drain the engine block, heater core hoses, and radiator. Start the car with the expansion tank cap off, let it run up to temp, and refill the reservoir when the thermostat opens.
'98 S70 T5
- 16 Replies
- 4467 Views
Last post by granite
- 4497 Views
Last post by rspi
- 13 Replies
- 7345 Views
Last post by Ozark Lee
- 4005 Views
Last post by MathalomuleM31
- 2875 Views
