engine warning light
martigan
Year and Model: 2000 XC70
Post by martigan »
Driving down the road when suddenly my check engine light came up. Just bought the car and it wasd safetied, certified and e tested..... any ideas as to why the light would come on?
louty
Year and Model: s70 1998
Post by louty »
get a code reader to check out why its on, but if you just bought it and it was certified used car, take it back and let them deal with it
rmmagow
Year and Model: V70 1998
Been thanked: 2 times
Post by rmmagow »
"Certified" has many meanings. At a used car lot it generally means tires hold air at least over night, you can put gas in it and headlights probably work. Now if it came with a warranty then they may be required to fix your problem. Buy a cheap code reader though, older Volvos like to turn that light on for every little thing that goes wrong. Get the code, Google it and read up about it. That will give you a good idea regarding something serious going on or just a leaky vacuum line.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
martigan
Post by martigan »
thanks for the response. disconnected the negative battery connector for 10 minutes. came back, reinstalled and voila...light is off. Looking into a code reader as i type....so far, loving the ride.
