Car rocks backwards when handbrake applied!!??
Andrew
Post by Andrew »
Hi guys,
just wondered if you could help with this one. when my v70's handbrake is applied the car rocks backwards. also when i try and pull away i have to pull forwards before being able to reverse. i took it to the volvo main dealer and they said it was water on the discs, but i dnt see how water can hold 5 people and their luggage.
any ideas??
Thanks
Andrew
bill740
Year and Model: 2006 V70, 1990- 740
Post by bill740 »
v70s and you did not specify year brake setup on all v70s are similar their is a separate set of shoes a small drum inside the rear rotor (part of the rotor) the shoes grab the inner drum and since the engagement is separate from the brake calapers and is only in the rear the weight of the car tends to shift to the back and the suspension squats/expands esp. on slopes. also check ot make sure the cable and park brake is releaseing properly otherwise it is ok.
fun to drive
AutoX47
Post by AutoX47 »
Hi Andrew, my names Andrew, I have the same problem Andrew, fcpgroton.com carries the shoes for inside the hats, Andrew, Good luck to you :)
Andrew Zizzo - ypc-inc.com
1996 Volvo 850 Turbo
iLLuZi0n
Post by iLLuZi0n »
someone said andrew alot ;) my name is carson, not andrew :P
i have an 850, and when i put the e-brake on in my car, i notice that the car dips in the rear, i am pretty sure thats what it is supposed to do, but im just contributing to the topic since im writing stuff :D
