Hi
My Volvo S80 airconditioning stops cooling after some time . Once when it stopped I checked and saw that the pipes were frozen . I was told that it could be that the thermistor is faulty. Where is the thermistor located? Does the dashboard need to be removes to reach that. Please do you have a diagram to show the exact position.
Thanks
Paul
where is the thermistor (aircon probefor a Volvo S80
jimmy57
- Been thanked: 320 times
remove left side under dash panel. The sensor is white with green electrical plug and is stuck into side of case just in front of those two aluminum heater pipes you will see on side of case. Twist it like it was a bulb socket to remove
- 615 Views
Last post by frebor72
- 712 Views
Last post by Starlifter
