P1332, no symptoms
EverRespect
- Year and Model: 2000 C70 Convertible
Cause for concern?
EverRespect
Only have 59k miles so no timing belt change. How do I fix it and what are the symptoms I should be looking for?
You might be able to free it up by just taking it for a long highway drive and bringing the engine over 4k RPM a few times.
http://volvoforums.com/forum/volvo-xc70 ... sue-42226/
The bearings on the timing belt tensioner/idler will wear out with time (7 yrs/80k replacement interval iirc), so if you end up needing to replace the whole VVT solenoid I would do the timing belt with it.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
The VVT solenoid can be removed and cleaned. With so few miles in the last 13 years, it is probably time to replace the timing belt, tensioner, and rollers regardless of the mileage. If you still have OEM tires, they have dry rotted.
Klaus
EverRespect
I'm strongly considering just clearing the code and selling the car. Just put $700 for a XeMODeX ETM and I have had the car since Feb 7. I'm sure as hell not doing all that timing belt work now, especially if I am not showing any actual symptoms. The tires are new.
How do I clean the solenoid? Just contact cleaner on all the wiring or is there more to it? And again, what kind of symptoms can I expect over time if I simply ignore this code?
Klausc
Cleaning the solenoid itself is not easy work, dealers will just replace it for a small fee $$$. First check the electrics with a multimeter: when unplugged, the solenoid should show approx 3.7 ohms resistance.
The reason for VVT is for better performance at higher rpm.
Klaus
EverRespect
Well, since I am not getting any good reason to fix this, I just bought a cheap $20 scanner from Amazon and cleared the code. Will continue to do so if it comes back and deal with it if/when there are drivability symptoms.
- 3364 Views
Last post by RichCrewe
- 1149 Views
Last post by calvolvo
- 2475 Views
Last post by v-45magna
- 1822 Views
Last post by bmdubya1198
- 12 Replies
- 4056 Views
Last post by JRL
