No Light on OBD
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
1FastCookie
Year and Model: 1995 960 Sedan
No Light on OBD
Post by 1FastCookie »
I have a check engine light on. The OBD doesnt respond to give any codes. When you turn on the key with the plug in #2 I get only a VERY dim glow. There are no flashes.
I also have a strange idle issue. The car idles at about 900 on a cold start. as it warms up the idle rises to around 1250 - 1350rpm. So at normal operatng temp the "idle" is constantly pushing the car when in gear.
Probably unrelated, but I also have an issue with the drivers power seat. When I bought the car for some reason there was no control module for the drivers seat. So I bought one and installed it. Still no poer seat movement. The connector under the front of the seat has power so there is power to the unit. Does the model have to marry the modulr to the master computer?
Go easy on me I'm a noob...
Thanks for any help.
1FastCookie
No one has seen the OBD not function? What do I do to fix or replace? I need to do a seat calibration. It appears that the calibration is done with the OBD. Its called a DTM4??
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Try this:
OBD unit does not flash.pdf
(79.74 KiB) Downloaded 162 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
1FastCookie
Finally!!! A simple solution!! My OBD is fully functional. The switch had corroded contacts. I cleaned them up and all is well.
Thanks Bill! Your awesome
billofdurham
Thank you for the update.
Bill.
Previously:
