Diff issue's????
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
MickS80
Year and Model: S80 2.0T 2002
Diff issue's????
Post by MickS80 »
So after I fixed the bump stops I now have an even bigger issue.
At all speeds but very bad between 20-60 kph the steering is 'kicking' left and right. Shudders under acceleration and car seems to kick side to side ever so slightly when braking softly.
If i drive slowly forward the steering will turn left after every rotation.
If the car is raised and in gear, I hold the front left wheel and it will stop, and there is a loud grinding noise also??
Am I looking at a diff replacement?
http://www.youtube.com/watch?v=SvvzEREN ... e=youtu.be
http://www.youtube.com/watch?v=ZEVVr8Xl7E4
http://www.youtube.com/watch?v=vPcUiUCC ... e=youtu.be
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
Usually diffs whine rather than grind. Could it be a binding brake caliper on the left side? The grinding noise you describe, does it only happen when you stop the front left wheel by hand?
Edit, disregard diff oil statement thought I was on the XC90 forum.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
MickS80
Post by MickS80 »
Yes if I hold the left wheel when its in first gear it will kick and grind.
Pads are new as are the disc and I don't think the caliper is binding as I cleaned them and they seemed to be ok, no discolouration on disc that I can see.
I really like My S80 but this is getting annoying :(
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
It sounds like you may have a badly binding CV joint. What condition are the boots in?
MickS80
Post by MickS80 »
chrism wrote:It sounds like you may have a badly binding CV joint. What condition are the boots in?
CV joint seems fine and boots are clean with no rips.....inner tie rods seem ok to.
Does a diesel gearbox fit a petrol model???
Ive checked every part that i can so its down to the diff and gearbox im thinking :(
ive changed wheels and tyres to no avail.
boosted5cyl
do the wheels turn smoothly by hand when they are off the ground. This is really weird! Generally diesel gearboxes are different, at the least the final drive tends to be.
MickS80
Post by MickS80 »
Soooo after feeling stupid for several days ha i found the problem.
1) As my near side wheel was spinning i noticed a bubble appearing in the tyre so that's one issue.
2) The bolt on the new cv joint had snapped?? God know how?
So after new Tyres and new cv bolt the car is once again sorted :/
