Rack and pinion play on the inside
All tie rods are in good shape, but where the steering column enters the steering box there is play or slippage. Is there a big bolt with locking nut on the steering box, that adjusts the tightness of the pinion gears? Driving the car and you can hear the racks loose on the pinion gear, when going over bumps.
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
burnout8488
- Year and Model: 1999 S70 AWD
Did this on my 850, not sure if it's exactly the same for your P2 vehicle... but it might be!
You need to be very careful with this adjustment. Notice how I marked mine. Make a 1/8th turn clockwise, then test. It is a 10mm hex plug. In an 850, all of the rack's mounting hardware will need to be disconnected as there is a plate that covers this up. I sagged the subframe down in the rear, and left the steering shaft connected.
It took two clockwise 1/8th turns to eliminate the "on-center" play of my freshly REBUILT rack. Rack gears tend to wear in this area and the pinion preload needs to be adjusted to compensate for it.
Test for binding when turning left and right while making the adjustment. If it feels abnormally tight, you've gone too far. When done, stake the adjuster to the rack using a screwdriver so it cannot move. (The initial turn will break the stake made at the factory)
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
burnout8488
Me too, good luck! If you find yourself under the wagon checking it out, post a pic. I'm interested in seeing the subframe differences and if the rack uses the same 10mm hex adjuster.
