Fuel Injectors - Improve Performance & Economy FF#39
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Missed last week? No Turbo? No Problem! Part 3 Take the Fast Friday Poll.
They're Often Forgotten
Fuel injectors don’t typically generate a lot of interest unless it’s time to upgrade them. Since we’re wrapping up the non-turbo build, and since we have a brand new injection test machine here at ARD, I thought I’d cover injector servicing this week!
Fuel injectors typically either work or don’t and there’s not much in between. However they can become clogged or partially obstructed. Each fuel injector has its own small filter in the top entry port called the ‘filter basket’ and these can easily become blocked or obstructed with particulate such that injection flow is compromised. Balanced injectors are important to both good fuel economy and performance as an uneven fuel distribution to the motor can make for rough idle and inconsistent fueling to each cylinder.
These injector filters commonly collect up bits of dirt and debris from the fuel tank as well as fuel filter media. Fuel filter media is more typical for cars that have not had the fuel filter replaced in a timely fashion and in turn the filter media has started to come apart and head downstream along with the fuel. For some reason fuel filters seem to be commonly over looked as a maintenance item.
Servicing injectors includes replacing o’rings, filter baskets, and retainers. Additionally ultrasonic cleaning with a proper cleaning solution helps break up any carbon buildup that can exist inside the injector from combustion gasses that can form on the injector after engine shut down. This occurs over a period of time so if you’ve got 50K plus miles on your injectors some gains in both power and economy can be had. We use Alconox as our cleaner since it is intended for use in the ultrasonic range and provides excellent breakup of hyrdrocarbon solids.
Here’s a set of injectors from the non-turbo build with 145K miles on them and as you can see these 4 units flow quite differently from one another. Typically the allowable variance is 5-10ml apart when measured at their max flow. Max flow for these injectors at 3 bar is 310ml/min. At 20 seconds of testing, not even the full minute, you can already see how much variance there is. Ultrasonic cleaning is what ultimately got these injectors back into proper flow range as the filter baskets were pretty clean and not the cause of the variance.
This should help keep the engine running smoother and with more consistent fueling that will hopeful promote some faster times as we head back to the track and finish up the non-turbo build!
Robert Lucky Arnold
[list][*]Questions, comments, arguments and freakouts accepted and encouraged. Really. Lucky WANTS to answer your questions.
[*]If you want to remain anonymous, email me your question or comment and I will post it as "Anonymous User".
[*]It takes Lucky and me several hours combined to bring you Fast Fridays. Your questions and comments validate FF's value.
[*]I write paragraph headlines, and sometimes article headlines. Yell at me if you find these not to your taste.
[*]Same thing with italics and bolds , they're all mine.
[*]Cams and turbos and MBCs and chips and... whoo![/list]
Matt
Reason: Added attribution.
Also -> Amazon link
boksalg
Year and Model: XC90 2.5T '05
Post by boksalg »
Love your site Matthew, people here are really nice and their collective knowledge outstanding!
What ultrasonic cleaner would you recommend?
I've seen smaller ones for jewlery but you're probably using a more industrial one?
matthew1
Site Admin
Post by matthew1 »
Hi Boksaig, thanks for the nice words. I forgot to add the bit at the end of this week's Fast Friday -- the attribution -- that tells that Lucky of ARD wrote this. :oops:
I'll correct that now.
So to stop writing this novel and answer your question, you'll have to ask Lucky, and in fact you just did. He monitors these Fast Friday posts, so he should be along soon.
Also -> Amazon link
CountryBum-kin
Year and Model: S60 2002
Post by CountryBum-kin »
Excellent post!
With the ever rising cost of fuel maximizing the engine's economy is a no brainer.
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
I just wonder where people send their injectors for cleaning?
ARD-Lucky
Year and Model: 1994
Post by ARD-Lucky »
We'll be offering injector cleaning/service shortly so keep an eye on our Facebook page and website for the latest.
As for a recommended cleaner, the harbor freight unit is ~$80 and does a pretty decent job for a basic unit :)
-Lucky
P.S. Thanks to Matt for all the work on making this forum great!
matthew1
Site Admin
Post by matthew1 »
Thank you, Lucky. Your Fast Fridays are awesome. "Performance" and good-running cars are -><- this close in reality. Here, let me Venn diagram it...
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Also -> Amazon link
Post by cn90 »
If you google "harbor freight ultrasonic cleaner", you will see people cleaning the injectors using the Ultrasonic Cleaner ($30 from Harbor Freight).
Not sure if it works. Anyone with experience doing Ultrasonic Cleaner , please chime in.
longhenrychan
Year and Model: 1993 Volvo 850 N/A
Post by longhenrychan »
I have difficulty finding the filter baskets for 850 injectors. Any sites would sell them?
