S70 Misfiring
bigrig1523
Year and Model: s70 1999
S70 Misfiring
Post by bigrig1523 »
Hello, I have a 1999 S70 and the other day driving on the highway I began to lose power and the check engine light began to blink. The same thing happened to me a few years ago and I changed the spark plugs and the problem was solved, not so lucky this time.
After I put in a new set of plugs, I had the codes pulled and originally it came up P0301 (misfire cylinder 1) but recently it's been coming up P0300 (misfire in multiple cylinders). I disconnected each individual coil packs, one at a time, while the engine was running and cylinders 1 and 2 were the only two that had no change on the rough running engine. The coil packs on cylinders 3, 4, and 5 when pulled almost made the engine stall. The other night I pulled the fuel rail and soaked the injectors over night in SeaFoam, reinstalled them the following morning and nothing changed. I'm not sure where to go from here. I think I've isolated the problem to cylinders 1 and 2. The check engine light was on previous to this incident but that was for the O2 sensor. Any help would be greatly appreciated. Thanks, Big Rig
Has thanked: 1505 times
Been thanked: 3818 times
Did you replace coils 1 and 2? You could swap coils 1 and 5, and then 2 and 5 (keeping the coil numbers the originals) to firm the diagnosis. If the 'weak cylinders move with the coil(s), VOILA!!
bigrig1523
I did, I swapped 1 with 5 and 2 with 5 and the engine again almost stalled when 4 and 5 were pulled and kept running rough when 1 and 2 were pulled. I failed to mention that.
I think that isolates you to either fuel injectors or valves in the affected cylinders.
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
How many miles? Do a compression check on the affected cylinders. You may have a valve leak. If so, you face some tough and/or potentially expensive decisions.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
bigrig1523
Thank you. 220000 miles on it. I haven't done a compression check yet but that was going to be my next step. I absolutely love the car but with 220K on it.....
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
Pull the rail and point it upwards with injectors installed. Have someone crank the car. You'll see a light mist from each injector. Whichever one isn't spraying is your problem. If all 5 are fine, you can rule that out.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
bigrig1523
All injectors appear to be firing correctly. I pulled cylinder 1 and 2's spark plug and it looked and smelled like fuel. I think a may have a few bad valves. Thanks for the help.
E Showell
Post by E Showell »
Running for prolonged periods with a vacuum leak, valve stem seal leaks, extended oil change intervals, running regular gas in normally aspirated models and failed front O2 sensors may all be possible causes of a burned valve. This has been covered extensively on this Board. Search away.
'95 855 auto (sold)
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
I have 225,000 and my compression numbers are 175+ across the board. Like a car with 50,000 miles on it. These motors are designed to last 500,000. Timely oil changes and good oil filters are the key. My PO changed oil all the time but didn't use proper oil filters and now my valve stem seals are bad. :?
