power loss - '83 244 fuel pump relay? - where is it?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
skiviskaves
Year and Model: 1983 244DL
Post by skiviskaves »
I’ve got a problem with intermittent loss of power/misfiring/poor acceleration on my ’83 244 DL. I joke that I have a brand new 1983 Volvo because over the last year I’ve replaced a lot of parts. I’ve read that the fuel pump relay might be the culprit. Can you tell me where to find the fuel pump relay? I thought it was one of the (2) black relays under the glove box but after replacing them, no improvement.
Also, the best place to purchase the fuel pump relay?
Some of the parts that I’ve replaced that could pertain to this problem: full tune up, plugs, wires, rotor, cap, throttle position sensor, idle air control valve, in tank fuel pump, fuel filter, air filter, cleaned but did not replace MAF, O2 sensor, a couple vacuum lines.
Also, there is a smell of fuel and there was some fuel in the air intake tube behind the MAF when I cleaned that.
THANKS!!!
rgk
Year and Model: Gray 88 245
Has thanked: 1 time
Post by rgk »
You should look for a fuel leak and check your fuel pressure.
rgk -- was dickdeadly
kenwood
Post by kenwood »
I have the same question, where exactly is the fuel pump relay on an '83 244DL? Thanks!
kenwood
Post by kenwood »
Found 'em, you are right, there are two. And they're mounted together behind the glove compartment. One of mine was intermittent causing the engine to quit and required replacement. These are simple on/off relay switches, the fuel pump will not run at all if they fail.
