A/C Recharge on P-2 V-70R
SimLyons
Year and Model: 2001 V70 T5
Post by SimLyons »
Today, as our temps soared into the low 80s I thought it a good time to check my A/C. To make a short story even shorter there is no Chill to my AC. Tried all the usual steps and then went and got an extra can of RS 134a and went to connect to the LP valve. The connector on the car is too large by about 1mm diameter.
So I tried another brand which I just bought (NAPA) and same thing.
Does anyone know if there is an adapter for this newer and larger connector? Or is this something to get us back in the Genuine Dealerships? (I have an appointment for Monday just in case).
Thanks! Sim
Sim
wheelsup
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
Are you sure it's the correct port? I don't have a P2 but they should all be standard connections.
SimLyons
Post by SimLyons »
Yeah, they should be all the same. I have had many Volvos prior to this one and never had any problems with the connector. I'll look around to see if there are any others. This one is high and in front of the Radiator.
Weird!
Sim
David in NC
Year and Model: 1999 V70
Post by David in NC »
The port on my 99 is low on the passenger side between the radiator and the serpentine belt.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Sim you're looking at the wrong (high pressure) port, that's why it is a different size.
Try the P2 forum or the A/C master topic:
https://www.matthewsvolvosite.com/forums ... =4&t=48233
For basic recharge info, the master topic will take you to this link and you'll be able to locate the port near the P/S pump
Volvo air conditioning problems and fixes
Has thanked: 1613 times
Been thanked: 4078 times
...and it is a good thing your can doesn't fit on the high pressure side! That's by design of course.
SimLyons
Post by SimLyons »
Thanks guys, esp Eric for the link. That's exactly what I needed!
Sim
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
Know the source of your leak? Fix it before you dump money into cans of refrigerant!
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
SimLyons
Post by SimLyons »
No leak,yet. Had it completely evacuated and recharged on Last Monday And so far so good. Good, solid cool air. Off to the detail shop on Wednesday, I hope. Then LOTS of photos and a better write-up.
Will lay it down in E-Bay, on Craigs List and a few Volvo Tracks, including the king of all, MVS!!
Sim
