Innova 3130 won't read live data or codes on my '96
Marcobrick
Year and Model: 2003 V70T5
Has thanked: 3 times
Post by Marcobrick »
My '96 850has a check engine light on. I have an Innova 3130 scan tool and it comes back with 'no dtc stored on the vehicle's computer' it also fails to read live data on this car. It worked perfectly on my 98 V70T5 I used to own. Anybody had a similar experience?
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
1973 Land Rover Series 3 flat deck.
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1995 850 Turbo Wagon
1998 V70T5
Favourite line: "How hard can it be?"
Townhouse
Year and Model: 1993 850, 1987 740Tu
Post by Townhouse »
Does anyone know what scan tools work on the 1993 850 and where does one make the connection between the car and the scan tool?
Marcobrick
A 93 should have the diagnostic boxes under the hood
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Marcobrick
I changed the thread title to clarify the issue.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I had a 3130 and it worked alright on my 96, but it sometimes took multiple attempts to get it to connect.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
Marcobrick
Mine connects just fine, I get a solid green LED on the emissions status, but despite the fact I have a CEL it tells me there are no codes. The thing that makes less sense is that no live data is displayed, just a blank screen. The code reader works fine on my other car (a 2000 Peugeot)
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
indianajoel
Year and Model: 91 240,96 850, 98V70
Post by indianajoel »
I've seen wiring or fuse problems on the way to the car's DLC cause my scanner (a 3140) to fail to read codes.
That's just a thought.
I hope you figure it out. Let us know.
Previous Volvos: '86 245, '89 245, '89 744, '63 PV544
Other current drivers: '95 Dodge Cummins 4wd, '86 Nissan D21 Pickup
Marcobrick
The CEL has healed itself. I still have no idea what it was. Still no live data either. If it was a fuse, the scanner wouldn't get any power fom the vehicle connector would it? Mine is connecting. I wonder if it is a wiring problem on one of the pins. A can of worms I don't want to get into...I hate wiring!
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Marcobrick
I had a cam sensor issue the other day which I replaced. When I started the car it had a misfire due to a wet plug. I thought this would at least trip a CEL with a misfire code, but no. How long does it need to run on 4 cylinders to throw a code?
Every time I plug my scanner in, even with a CEL lit, it says "no DTCs stored on the vehicle computer" and I always get the steady green I/M readiness light.
I still can't get any live data either.
2008 XC90 D5
2014 Nissan Leaf
1973 Fiat 125
1970 MGB GT
Previously:
2003 V70T5
1996 850R sedan
1994 850T5 Sedan
1998 V70T5
Has thanked: 292 times
Been thanked: 765 times
Post by erikv11 »
This sounds like a problem with the OBD system, maybe not the reader at all. Misfire codes show up right away when running on 4 cylinders, I know that firsthand.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
