Resetting service light
This topic is in the MVS Volvo Repair Database » Does my Volvo 850 have Motronic 4.4?
DavidsVolvo
Year and Model: 1998 V70, 1999V70XC,
Post by DavidsVolvo »
I have a 1998 V70 FWD and a 1999 V70 XC. Both cars have the service light on for the first 2 minutes. I have a OBD-II high end diagnostic instrument by AUTEL. I can even select the exact Volvo year, type engine etc. But no where does it allow me to rest the service light. How do I do this?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
By the dealer or the correct tool
jonesboy1983
Year and Model: V70 2007
Post by jonesboy1983 »
It's also not too hard to take out the dash panel and just remove the bulb. IPD has a video on it for replacing the bulbs.
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
+14,000: remove the bulb!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
AND THEN SMASH IT!
'98 S70 T5
2016 Chevy Cruze Premier
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
The simplest solution:
Cut a piece of black electrical tape about 3/4" by 3/4" and place it over the light.
I did that many many years ago and never look back.
jblackburn
cn90 wrote:The simplest solution:
The Homer Simpson method ;)
'98 S70 T5
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2866 times
Been thanked: 1332 times
Post by matthew1 »
Except Homer would put tape over the whole instrument cluster ;-)
Also -> Amazon link
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
Yeah, the '98 needs a tool, but it's an exception.
You should be able to reset the '99 pretty easily.
Key turns and button pushes, isn't it?
Has thanked: 1614 times
Been thanked: 4078 times
On the 1999
Ignition off.
Press in trip odometer reset button.
Switch on ignition.
Continue pressing in the reset button for 10 seconds. (Sing one third of the "Final Jeopardy" theme
Release reset button within 4 seconds.
Horrible advice, Shirley....
It's 19mm x19mm, and the electrical tape colour must match the body exterior, of course.
