92, 940GL - low pedal after master cylinder replacement
bobman
Replaced leaking master cylinder, bench bled it prior to installing, bled the entire brake system, still have very low pedal. Vehicle has ABS, any ideas on what the problem is and how to correct it.
Guest
abs is bled differently than other systems bleed wheel with shortest brake line first, next shortest next etc. It is just the opposite with non abs with non abs you start with the longest brake line first.
