Oil on cam cover
dl3250
Year and Model: S70 2000
Post by dl3250 »
I just got my 2000 S70 running again. I did the cam seals and pcv system. I am still getting oil all over the top of the engine. Would the pcv system be clogged inside of the block? Could I just blow back through the line that runs to the top of the engine? I made sure it was clear when I put the pcv back on, but it seems like it is still building pressure. I also replaced the oil cap gasket. Its looks like that is where its coming from.
Thanks
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Maybe worn piston rings, do a compression test.
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Did you clean out the port at the bottom of the oil trap, where oil drains back into the block? This is the main trouble spot for PCV clogs.
Is your car turbo or non-turbo (would help to include that in the "Model, year" information)?
dl3250
Post by dl3250 »
The car is non turbo.I did clean that port and it was really clogged. I had to blow some air through to get any flow at all. I'll do a compression test when I get a chance, but judging by the way it runs I would be surprised if the rings are blowing by that much.
gmh
Year and Model: 2016 XC60 T5
Has thanked: 28 times
Been thanked: 22 times
Post by gmh »
Another possible solution to oil on the cam cover:
http://www.ipdusa.com/products/5884/115 ... l-cap-seal
Gary
1969 145S (1987-91)
1973 145E (1989-90)
1981 245 (1990-2001)
1981 244 (1991-2002)
1989 760 Turbo Wagon (1999-2011)
1994 850 Turbo Wagon (2002-2013) burnt valve
2001 V70 2.4T (2009-2017) sold
1997 850 R Wagon (2013-2025) sold to Matthew
2014 XC60 T6 (2017-present)
2016 XC60 T5 (2024-present)
dl3250
Post by dl3250 »
Well for the price I guess thats worth a try. The one that's on it is fairly new but it never felt real tight.
Thanks
shaker_chi
Year and Model: 94 850, 98 S70T5 M
Has thanked: 3 times
Been thanked: 3 times
Post by shaker_chi »
I had the same issue. The oil cap never felt like it sealed properly. I doubled up on the gasket and I don't have oil under my spark plug cover anymore.
Ed
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Good advice here. Make sure that lower port is clear and that you DO NOT have smoke still coming up the dipstick when you rev up the motor.
If that's all good, then replace the oil cap seal or get another cap.
I've also had problems with that hose to the top of the cam cover seating correctly and leaking oil.
'98 S70 T5
2016 Chevy Cruze Premier
obayha
Year and Model: V70 1999 Base
Been thanked: 2 times
Post by obayha »
If you had to blow the port going into the motor to open it up, it may be a good thing to change the oil filter, if you haven't done that after the PCV fix.
1998 V70 T5 331,000 :( Her last day was on 3 cylinders.
New to me 1999 V70 NA 163,000 Now at 217,000
2006 V70 2.5T in driveway (WIFE'S)
1982 Toyota FJ40 Land Cruiser
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
jblackburn wrote:...
The correct diameter Oetiker clamp is best suited to prevent leaking oil at this connection.
