'96 960 Wagon popping noise when turning
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
asg1986
Year and Model: 945T,244,P1800,S60s
Post by asg1986 »
Hello,
Has anyone ever experienced a popping noise when turning the steering wheel? It occurs when the car is rolling, or when it is stopped, and occurs when I'm turning the wheel in either direction. The noise comes from both the left and the right side of the car. I lifted it and checked ball joints. They were okay, so I replaced the inner tie rods, and while I was at it I replaced the sway bar endlinks. I know these can make a popping noise on S70's/ 850 (I'm more familiar with their noises). Any ideas? This is a car I bought with a bad transmission and engine, so both have been swapped out. I don't know if the car had this issue before as I couldn't drive it. The upper strut mounts don't move when the wheel is turned either, so I'm pretty sure I can rule this out... Thanks!
Reason: Lowercased title
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Steering column to steering rack u-joints?
1988 Volvo 760 Turbo Wagon
asg1986
Post by asg1986 »
Can these be sprayed with WD-40 like a 240 Steering U-Joint? :roll: Or is there another trick? Any way to test? Will it not make a knock when the suspension is loaded?
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
popping when body roll?
---could be the strut braces/spring seats going bad.
How many miles on the car?
Does it do this while the car is ditting still?>
Does it squeal when you turn? if so, check the steering fluid, steering box could be losing oil
Check the belts? are they tight? cracked?
Check the sway bar end links.
Bounce the front end? does it knock?
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
lummert wrote:Steering column to steering rack u-joints?
Also take a quick look at the collar from inside near pedal.
u-joint at the collar near pedal
