Front Camshaft Oil Leak
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
quaverous
Year and Model: 2006 S40 T5
Post by quaverous »
I am slowly taking my 2006 S40 Turbo apart to replace a leaky front intake cam seal. Looking through the forums, it has been tough to find step-by-step instructions for replacing 2004+ S40 cam seals and I need some help. Currently, I have the rear of the cams locked into position and about to remove the cam gears.
1. From other threads it appears that cam gears can be stubborn. Is the locking tool (I have the full kit in the red case) enough to get the gears off without stripping the slots? What about reattaching the gears with 120 Nm?
2. When I pulled out the rear cam plugs, I didn't see oil seals. Does the 2006 S40 have rear seals inside the plugs? Just curious as I thought I'd replace them while I have stuff apart.
3. Any special tools for removing the front cam seal and installing a new seal? There have been mixed responses in various threads but nothing specific to an 06 S40.
4. Left field question: if the front cam seal is not the problem, which means the cvt gear is the culprit, do I need an entire new gear or just new rings?
Thank you in advance!
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
quaverous wrote:I am slowly taking my 2006 S40 Turbo apart to replace a leaky front intake cam seal. Looking through the forums, it has been tough to find step-by-step instructions for replacing 2004+ S40 cam seals and I need some help. Currently, I have the rear of the cams locked into position and about to remove the cam gears.
This post is relevant, and may have answers for some if not all https://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=53722
JDS60R
Been thanked: 3 times
Post by JDS60R »
Now I know why you couldn't find it.
I do not know the structural integrity of the tool you mentioned. Please report back on how it worked.
S40 accesory belt.pdf
(150.61 KiB) Downloaded 211 times
s40 air cleaner.pdf
(255.85 KiB) Downloaded 226 times
S40 battery disconnect procedure.pdf
(137.6 KiB) Downloaded 287 times
S40 cam seal.pdf
(144.62 KiB) Downloaded 597 times
S40 ECM.pdf
(109.83 KiB) Downloaded 269 times
S40 engine isolator.pdf
(168.89 KiB) Downloaded 200 times
S40 starter motor.pdf
(168.72 KiB) Downloaded 241 times
S40 t belt.pdf
(387.05 KiB) Downloaded 428 times
S40 vvt.pdf
(362.83 KiB) Downloaded 444 times
Retired
quaverous
Post by quaverous »
Thanks guys for the links and PDFs. It is all very useful.
I now have the gear off to find the leak. Problem is that I don't know which (seal vs gear) is causing the problem. The seal looks good.
I know the leak is coming from seal/gear because oil fans out from below it, covering the timing belt and timing tensioner. I posted pictures up to see if anyone can spot the issue.
Here is the cam seal:
and here is the cam gear:
Any help is appreciated. Thank you.
JDS60R
Post by JDS60R »
replace the seal ($4 victor reinz from rockauto), clean the VVT and run it . I am bothered by the seal being dry 360 degrees around. Makes me think its the VVT but I can't see the surface the seal rides on in your pictures yet so its not time to judge.
Make sure the VVT is completely clean on the seal surface. ( no residue etc)
Retired
quaverous
Post by quaverous »
I was surprised the seal looked as clean as it did when I pulled the gear off.
The surface where the seal rides has a film of oil and looked smooth. I'll take another look at it tonight and look for any blemishes.
JDS60R
Post by JDS60R »
gently remove tarnish with acetone and red scotchbrite (fine metal grade in the direction it spins not in towards the engine- around the circle)
Retired
