2003 xc70, nothing on dash working?
my turn signal switch handle was broken and I thought that might be the cause, so I replaced it. But still no dash lights, turn signals still don't work ?? car runs fine, but no dash lights or gauges are working, no speedo, odometer etc.?? what is it? need help.
Reason: Removed extra ?? marks
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
You may need to pull out the the entire DIM (Drivers Interface Module, or instrument cluster) and, if it isn't something obvious like it came unplugged, send it off to Xemodex to have it tested/repaired.
If you dont know how to weld and such this is what I just did for my s60t 02
send out your cluster to get repaired for under $200. I just did it. Go to Ebay and lookup seller euro-electric. They give you easy instructions on how to pop out your panel, mail it to them and they ship it back fixed 1 2 3. Dont do like I did and wait for years and trying everything under the sun.
There are other sellers that seem more expensive out there.
or can search.
"VOLVO INSTRUMENT CLUSTER REPAIR". If you dont want to use ebay
you can just call them. 866 281 2414.
No I dont work there i just used their service and boy I wish i knew about it earlier
or can search.
- Smarzig
02 S60T 17"rims
02 S60T 17"rims
- 2816 Views
Last post by precopster
- 1616 Views
Last post by harpeed
- 1716 Views
- 389 Views
Last post by goldmandan
- 2162 Views
Last post by Stravlr
