Codes:
P0440 - Evap System Malfunction
P0452 (Pending) - Fuel tank pressure sensor low
Symptoms:
Dropped rear subframe, can't find any broken hoses or evap leaks.
FPR on top of the tank is good, fuel doesn't come out of the diaphragm when sucked on.
Sniffed all of the lines, can't find any obvious vapor leaks.
Applied 9V to the fuel pump with the line connected to the car, everything pressurized, no leaks whatsoever on top of the tank.
Applied 9V to the shutoff valve, closes and holds air until 9V is released. (Used a bike pump to put some air into the charcoal canister using the EVAP line in the engine bay)
Applied 9V to the purge valve, it doesn't allow air through when closed, DOES allow air through when 9V is applied. Proper operation.
Question:
What sort of testing should I do now? Pull a vacuum at the line in the engine bay and see if it holds?
The system holds pressurized air just fine, maybe vacuum is a different story?
What about the fuel tank pressure sensor, do these fail or is that a common code to pop up when there is a leak or other malfunction?
Any chance the check valves for the lines going to the purge valve might be bad?
Thanks!
Pressure sensor to the left of the blue port:
Shutoff valve and fuel filter:
